volume file clone deletion modify
Modify the supported file extensions for clone delete
The volume file clone deletion modify command can be used to change the required minimum clone file size of a volume for clone delete.
-vserver <vserver name>- Vserver Name-
Name of the vserver.
-volume <volume name>- Volume Name-
Name of the volume.
[-minimum-size {<integer>[KB|MB|GB|TB|PB]}]- Minimum Size Required for Clone delete-
Minimum clone file size required for clone delete.
The following example changes the required minimum file size to 100M for volume vol1 of vserver _ vs1 _ .
cluster1::> volume file clone deletion modify -volume vol1 -vserver vs1 -minimum-size 100M
