vserver cifs share access-control show
Display access control lists on CIFS shares
The vserver cifs share access-control show command displays the ACLs of CIFS shares.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
This optional parameter specifies the name of the Vserver containing the share for which you want to display the access control list.
[-share <Share>]- Share Name-
This optional parameter specifies the name of the CIFS share for which you want to display the access control list.
[-user-or-group <TextNoCase>]- User/Group Name-
If you specify this optional parameter, the command displays only access control lists for the CIFS shares that have ACLs matching the specified user or group.
[-user-group-type {windows|unix-user|unix-group}]- User or Group Type-
If you specify this optional parameter, the command displays only access control lists for the CIFS shares that have ACLs matching the specified user-group-type. The user-group-type can be one of the following:
windows
unix-user
unix-group
[-permission <access rights>]- Access Type-
If you specify this optional parameter, the command displays only access control lists for the CIFS shares that have ACLs matching the specified permission. The permissions can be one of the following:
No_access
Read
Change
Full_Control
[-winsid <windows sid>]- Windows SID-
If you specify this optional parameter, the command displays only access control lists for the CIFS shares that have ACLs matching the specified Windows SID.
[-unixId <integer>]- User/Group ID-
If you specify this optional parameter, the command displays only access control lists for the CIFS shares that have ACLs matching the specified unix user/group Identifier.
[-access-mask <Hex Integer>]- Access mask-
If you specify this optional parameter, the command displays only access control lists for the CIFS shares that have ACLs matching the specified access rights.
The following example displays all the ACLs for shares in Vserver vs1.
vs1::> vserver cifs share access-control show
Share User/Group User/Group Access
Vserver Name Name Type Permission
vs1 vol3 CIFSQA\administrator windows Read
vs1 vol3 Everyone windows Full_Control
vs1 vol3 pcuser unix-user Read
vs1 vol3 daemon unix-group Read
