Command reference
vserver delete
Delete an existing Vserver
The vserver delete command deletes a specified Vserver. If the Vserver is associated with one or more volumes, you must manually delete volumes (including mirror volumes) before you delete the Vserver. If there are recoverable volumes in the recovery queue, they will be purged. If the Vserver subtype is dp-destination , change the Vserver subtype to default by specifying the Vserver as the destination in the snapmirror break command before deleting the objects owned by the Vserver.
-vserver <vserver> - Vserver
This specifies the Vserver that is to be deleted.
[-foreground {true|false}] - Foreground Process
This optionally specifies the Vserver delete operation can be executed in the background. If nothing is specified, by default the Vserver delete operation is executed in the foreground.
The following example deletes a Vserver named vs2.example.com :
cluster1::> vserver delete -vserver vs2.example.com
