vserver delete
PDF of this doc site
Creating your file...
Delete an existing Vserver
The vserver delete
command deletes a specified Vserver. If the Vserver is associated with one or more volumes, you must manually delete volumes (including root and mirror volumes) before you delete the Vserver. If the Vserver subtype is dp-destination
, change the Vserver subtype to default
by specifying the Vserver as the destination in the snapmirror break command before deleting the objects owned by the Vserver.
-vserver <vserver>
- Vserver-
This specifies the Vserver that is to be deleted.
[-foreground {true|false}]
- Foreground Process-
This optionally specifies the Vserver delete operation can be executed in the background. If nothing is specified, by default the Vserver delete operation is executed in the foreground.
The following example deletes a Vserver named vs2.example.com
cluster1::> vserver delete -vserver vs2.example.com
