Command reference
network test-link show
Display test results
The network test-link show command displays the results of prior network test-link run-test commands.
The test results are stored non-persistently and can be viewed using the network test-link show command. Results include input parameters, date and time of the test, bandwidth achieved and the number of streams used.
[-fields <fieldname>,…​]
| [-instance ] (privilege: advanced) }
-node {<nodename>|local} - Node (privilege: advanced)
Selects the nodes that match this parameter value. Use this parameter to display the test results specific to a node. By default, the test results across all nodes are shown.
-vserver <vserver> - Vserver (privilege: advanced)
Use this parameter to display the test results specific to a Vserver. Use DC (Data Channel) Vserver option only in an ONTAP Select or Cloud Volumes ONTAP cluster to show network performance of links hosting DC LIFs. DC Vserver is a special Vserver that hosts LIFs that are used to mirror data aggregates to partner node
[-destination <Remote InetAddress>] - Destination (privilege: advanced)
Use this parameter to display the test results associated with the specified destination.
[-timestamp <MM/DD/YYYY HH:MM:SS>] - Time of Test (privilege: advanced)
Use this parameter to display the test results with the specified timestamp.
[-bandwidth <double>] - MB/s (privilege: advanced)
Use this parameter to display the test results only matching the specified bandwidth.
[-num-streams <integer>] - Number of Streams (privilege: advanced)
Use this parameter to display the test results only matching the specified number of streams.
The following example runs a test between the cluster LIFs twice and then demonstrates the show command results:
cluster1::*> network test-link run-test -node node2 -vserver Cluster -destination 172.31.112.173 -num-streams 4
Node: node2
          Vserver: Cluster
      Destination: 172.31.112.173
     Time of Test: 10/24/2025 16:12:19
             MB/s: 10299.11575470279
Number of Streams: 4
cluster1::*> network test-link show -node node2 -vserver Cluster
Node                Vserver             Destination       Time of Test          MB/s           Number of Streams
node2               Cluster             172.31.112.173    10/24/2025 16:12:19   10299.11575470279        4
cluster1::*> network test-link show -node node2 -vserver Cluster -instance
Node: node2
          Vserver: Cluster
cluster1::*> network test-link show -node node2 -vserver Cluster -fields num-streams
node                vserver destination     num-streams
node2               Cluster 172.31.112.173  4
cluster1::*> network test-link show -node node2 -vserver Cluster -num-streams 4
