ONTAP commands
network test-link show
Display test results
The network test-link show command displays the results of prior network test-link run-test commands.
The test results are stored non-persistently and can be viewed using the network test-link show command. Results include input parameters, the bandwidth achieved, and the date and time of the test.
{ [-fields <fieldname>,…​]
| [-instance ] }
-node {<nodename>|local} - Node (privilege: advanced)
Selects the nodes that match this parameter value. Use this parameter to display the test results specific to a node. By default, the test results across all nodes are shown.
-vserver <vserver> - Vserver (privilege: advanced)
Use this parameter to display the test results specific to a Vserver. Use DC (Data Channel) Vserver option only in an ONTAP Select or ONTAP Cloud cluster to show network performance of links hosting DC LIFs. DC Vserver is a special Vserver that hosts LIFs that are used to mirror data aggregates to partner node
[-destination <Remote InetAddress>] - Destination (privilege: advanced)
Use this parameter to display the test results associated with the specified destination.
[-timestamp <MM/DD/YYYY HH:MM:SS>] - Time of Test (privilege: advanced)
Use this parameter to display the test results with the specified timestamp.
[-bandwidth <double>] - MB/s (privilege: advanced)
Use this parameter to display the test results only matching the specified bandwidth.
The following example runs a test between the cluster LIFs twice and then demonstrates the show command results:
cluster1::*> network test-link run-test -node node2 -vserver Cluster -destination 172.31.112.173
Node: node2
     Vserver: Cluster
 Destination: 172.31.112.173
Time of Test: 4/25/2016 10:37:52
        MB/s: 29.9946
Node: node2
     Vserver: Cluster
Time of Test: 4/25/2016 10:38:32
  MB/s: 39.8192
cluster1::*> network test-link show -node node2 -vserver Cluster
Node                Vserver             Destination       Time of Test          MB/s
node2               Cluster             172.31.112.173    4/25/2016 10:38:32         39.8192
