Command reference
vserver nvme show-discovery-controller
Display active NVMe discovery controllers
The vserver nvme show-discovery-controller command displays information for established NVMe controllers on the discovery subsystem. An NVMe controller is established upon each host connection to the discovery subsystem.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver Name
Use this parameter to display the NVMe controllers that match the Vserver that you specify.
[-controller-id <Hex 16bit Integer>] - Controller ID
Use this parameter to display the NVMe controllers that match the controller ID that you specify. The controller ID is the identifier assigned by the NVMe subsystem upon host login and controller creation.
[-discovery-nqn <text>] - Discovery Subsystem NQN
Use this parameter to display the NVMe controllers that match the discovery subsystem NQN that you specify.
[-lif <text>] - Logical Interface
Use this parameter to display the NVMe controllers that match the LIF that you specify.
[-node <nodename>] - Node
Use this parameter to display the NVMe controllers that match the cluster node that you specify.
[-host-nqn <text>] - Host NQN
Use this parameter to display the NVMe controllers that match the host NQN that you specify. The host NQN is the NVMe identifier assigned to a specific host.
[-transport-protocol {fc-nvme|nvme-tcp}] - Transport Protocol
Use this parameter to display the NVMe controllers that match the transport protocol that you specify.
[-initiator-transport-address <text>] - Initiator Transport Address
Use this parameter to display the NVMe controllers that match the initiator transport address that you specify. The initiator transport address format depends on the transport protocol in use.
[-trsvcid <text>] - Transport Service Identifier
Use this parameter to display the NVMe controllers that match the transport service identifier that you specify.
[-host-id <Hex String>] - Host Identifier
Use this parameter to display the NVMe controllers that match the host identifier that you specify. The host identifier is a 128-bit identifier assigned to a specific host.
[-admin-queue-depth <integer>] - Admin Queue Depth
Use this parameter to display the NVMe controllers that match the administrative queue depth that you specify.
[-header-digest-enabled {true|false}] - Header Digest Enabled
Use this parameter to display the NVMe controllers that have header digest enabled.
[-data-digest-enabled {true|false}] - Data Digest Enabled
Use this parameter to display the NVMe controllers that have data digest enabled.
[-kato <integer>] - Keep-Alive Timeout (msec)
Use this parameter to display the NVMe controllers that match the keep-alive timeout value (in msec) that you specify.
cluster1::*> vserver nvme show-discovery-controller -vserver vs1
Vserver ID    LIF  Host NQN
vs1     0041h node1_e0f
                   nqn.2001-08.example.com:nvme:host1
vs1     0080h node2_e0f
                   nqn.2001-08.example.com:nvme:host2
2 entries were displayed.
