vserver cifs share show
Display CIFS shares
The vserver cifs share show command displays information about CIFS shares. The command output depends on the parameter or parameters specified with the command. If you do not specify any parameters, the command displays the following information about all CIFS shares:
Vserver name
CIFS share name
Path
Share properties
Comment
You can specify additional parameters to display only information that matches those parameters. For example, to display information only about CIFS shares that use dynamic shares, run the command with the `-share-properties dynamicshare` parameter.
[-fields <fieldname>,…] -
If you specify this parameter, the command only displays the fields that you specify.
[-shadowcopy ] -
If you specify this parameter, the command displays information only about CIFS shadow copy shares.
[-umask ] -
If you specify this parameter, the command displays file and directory masks for CIFS shares.
[-instance ]} -
If you specify this parameter, the command displays detailed information about all CIFS shares.
[-vserver <vserver name>]- Vserver-
If you specify this parameter, the command displays information only about CIFS shares on the specified CIFS-enabled Vserver.
[-share-name <Share>]- Share-
If you specify this parameter, the command displays information only about the CIFS share or shares that match the specified name.
[-cifs-server <NetBIOS>]- CIFS Server NetBIOS Name-
If you specify this parameter, the command displays information only about the CIFS share or shares that use the CIFS-enabled Vserver with the specified CIFS server name.
[-path <text>]- Path-
If you specify this parameter, the command displays information only about the CIFS share or shares that have the specified path.
[-share-properties <share properties>,…]- Share Properties-
If you specify this parameter, the command displays information only about the CIFS share or shares that have the specified share properties.
[-symlink-properties {enable|hide|read-only|symlinks|symlinks-and-widelinks|disable|no-strict-security}]- Symlink Properties-
If you specify this parameter, the command displays information only about the CIFS share or shares that have the specified symbolic link properties.
[-file-umask <Octal Integer>]- File Mode Creation Mask-
If you specify this parameter, the command displays information only about the CIFS share or shares that use the specified file mask.
[-dir-umask <Octal Integer>]- Directory Mode Creation Mask-
If you specify this parameter, the command displays information only about the CIFS share or shares that use the specified directory mask.
[-comment <text>]- Share Comment-
If you specify this parameter, the command displays information only about the CIFS share or shares that have the specified comment.
[-acl <text>,…]- Share ACL-
If you specify this parameter, the command displays information only about the CIFS share or shares that have the specified ACL.
[-attribute-cache-ttl <[<integer>d][<integer>h][<integer>m][<integer>s]>]- File Attribute Cache Lifetime-
If you specify this parameter, the command displays information only about the CIFS share or shares that have the specified attribute-cache-ttl for attribute cache.
[-volume <volume name>]- Volume Name-
If you specify this parameter, the command displays information only about the CIFS shares that are present in this volume.
[-offline-files {none|manual|documents|programs}]- Offline Files-
If you specify this parameter, the command displays information only about the CIFS shares that have the specified Offline Files properties.
[-vscan-fileop-profile {no-scan|standard|strict|writes-only}]- Vscan File-Operations Profile-
If you specify this parameter, the command displays information only about the CIFS shares that have the specified Vscan fileop profile.
[-max-connections-per-share <integer>]- Maximum Tree Connections on Share-
If you specify this parameter, the command displays information only about the CIFS shares that have the specified maximum connections per share configured.
[-force-group-for-create <text>]- UNIX Group for File Create-
This optional parameter displays information about the CIFS shares that have the specified "force-group" parameter configured.
The following example displays information about all CIFS shares:
cluster1::> vserver cifs share show
Vserver Share Path Properties Comment ACL
vs1 ROOTSHARE / oplocks Share CNC \
browsable mapped Everyone /
changenoti to top Full
fy of Control
Vserver
global
namespac
e
vs1 admin$ / browsable - -
vs1 c$ / oplocks - BUILTIN\Admi
browsable nistrators /
changenoti Full
fy Control
vs1 ipc$ / browsable - -
4 entries were displayed.
The following example displays information about a CIFS share named SALES_SHARE on a Vserver named vs1.
cluster1::> vserver cifs share show -vserver vs1 -share-name SALES_SHARE
Vserver: vs1
Share: SALES_SHARE
CIFS Server NetBIOS Name: WINDATA
Path: /sales
Share Properties: oplocks
browsable
Symlink Properties: enable
File Mode Creation Mask: -
Directory Mode Creation Mask: -
Share Comment: -
Share ACL: Everyone / Full Control
File Attribute Cache Lifetime: -
Offline Files: manual
Vscan File-Operations Profile: standard
