Command reference
network arp delete
Delete static ARP entry
The network arp delete command deletes static ARP entries from the Vserver and from the network stack.
-vserver <vserver name> - Vserver Name
Use this parameter to specify the name of the Vserver from which the ARP entry is deleted.
-remotehost <IP Address> - Remote IP Address
Use this parameter to specify the IP address of the ARP entry being deleted.
The following example deletes the ARP entry for IP address 10.63.0.2 from the Vserver vs1.
cluster1::> network arp delete -vserver vs1 -remotehost 10.63.0.2
