network arp delete
Delete static ARP entry
The network arp delete
command deletes static ARP entries from the Vserver and from the network stack.
-vserver <vserver name>
- Vserver Name-
Use this parameter to specify the name of the Vserver from which the ARP entry is deleted.
-remotehost <IP Address>
- Remote IP Address-
Use this parameter to specify the IP address of the ARP entry being deleted.
The following example deletes the ARP entry for IP address 10.63.0.2 from the Vserver vs1.
cluster1::> network arp delete -vserver vs1 -remotehost 10.63.0.2
