statistics preset show
Display information about Performance Presets
Displays information about performance preset configurations.
[-fields <fieldname>,…]-
Selects which performance preset attributes to display.
[-instance ](privilege: advanced) } -
Shows details of all attributes of performance preset configuration.
[-preset <text>]- Preset Name (privilege: advanced)-
Selects the performance presets that match the specified preset name.
[-comment <text>]- Preset Description (privilege: advanced)-
Selects the performance presets that match the specified comment.
[-privilege <PrivilegeLevel>]- Preset Privilege Level (privilege: advanced)-
Selects the performance presets that are available with the specified privilege.
[-store <text>]- Name of Store Where Data is Saved (privilege: advanced)-
Selects the store where data is saved.
[-is-read-only {true|false}]- Is Preset Read-Only? (privilege: advanced)-
Selects the performance presets that are read-only (true) or are not read-only (false). Read-only presets cannot be modified.
cluster1::*> statistics preset show
Preset Name: aggregate_overview
Preset UUID: 4ec14b86-34a0-11ef-8db4-005056bb1920
Comment: This preset configuration is used by statistics aggregate
show command. Provides overview of aggregate object.
Privilege: admin
Read-Only: true
Negative Preset: false
Application Order: 1
Archive Enabled: false
Store Name: -
Generation ID: 0
Preset Name: disk_overview
Preset UUID: 4e7471b3-34a0-11ef-8db4-005056bb1920
Comment: This preset configuration is used by statistics disk show
command. Provides overview of disk object.
Privilege: advanced
Read-Only: true
Store Name: -
Generation ID: 0
Preset Name: fcp_port_overview
Preset UUID: 4e77ed6e-34a0-11ef-8db4-005056bb1920
Comment: This preset configuration is used by statistics port fcp
show command. Provides overview of fcp port object.
Privilege: admin
Read-Only: true
Store Name: -
Generation ID: 0
Preset Name: flash_pool_overview
Preset UUID: 4ecd2576-34a0-11ef-8db4-005056bb1920
Comment: This preset configuration is used by statistics cache
flash-pool show command. Provides overview of flash pool
object.
Privilege: admin
Read-Only: true
Store Name: -
Generation ID: 0
