snapmirror object-store profiler abort
PDF of this doc site
Creating your file...
Your file is ready
Abort object store profiler
The snapmirror object-store profiler abort
command will abort an ongoing object store profiler run. This command requires two parameters - an object store configuration and a node on which the profiler is currently running.
-node {<nodename>|local}
- Node on Which the Profiler Should Run (privilege: advanced)-
This parameter specifies the node on which the object store profiler is running.
-object-store-name <text>
- Object Store Configuration Name (privilege: advanced)-
This parameter specifies the object store configuration that describes the object store. The object store configuration has information about the object store server name, port, access credentials, and provider type.
The following example aborts the object store profiler :
cluster1::>snapmirror object-store profiler abort -object-store-name my-store -node my-node
