Command reference
network cloud routing-table delete
Delete an existing external routing table
The network cloud routing-table delete deletes an existing external routing table.
-route-table-id <text> - Route Table ID (privilege: advanced)
This parameter is used to provide the name of an existing external routing table to be deleted.
The following example deletes the external routing table "eni-123456":
cluster1::> network cloud routing-table delete -route-table-id eni-123456
