Command reference
template download
Download a template
Use this command to download a template from an external server to the cluster.
-uri {scheme:​//(hostname|IPv4 Address|'['IPv6 Address']')…​} - URI of the template (privilege: advanced)
This parameter specifies the URI from which the template will be downloaded.
[-name <template name>] - Name of the template (privilege: advanced)
This parameter specifies the name that will be assigned to the template in the cluster.
The following example downloads the template specified in the -uri parameter value and names the template as template1:
cluster1::> template download -uri http://www.example.com/netapp-templates/mysample -name template1
The following example downloads the template specified in the -uri parameter value:
cluster1::> template download -uri http://www.example.com/netapp-templates/template1
