security key-manager keystore show
Displays the configured key manager keystores.
This command displays all keystore configurations.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <Vserver Name>]- Vserver
If you specify this parameter, then the command displays only the keystore configurations with the given Vserver.
- [-keystore-type <Key Store Type>]- Keystore Type
If you specify this parameter, then the command displays only the keystore configurations with the given keystore type.
- [-config-name <text>]- Configuration Name
If you specify this parameter, then the command displays only the keystore configurations with the given configuration name.
- [-enabled {true|false}]- Configuration Is Enabled?
If you specify this parameter, then the command displays only the keystore configurations with the given enabled value.
- [-uuid <UUID>]- Key Store UUID
If you specify this parameter, then the command displays only the keystore configuration with the given universal unique identifier (UUID) value.
- [-state <Key Store state>]- Key Store State
If you specify this parameter, then the command displays only the keystores with the given state.
The following example lists all keystore configurations.
Cluster-1::*> security key-manager keystore show Vserver Keystore Type Config Name Enabled ---------------------- -------------- ------------------ ------- Cluster-1 OKM default true vs0 AKV default true vs0 AKV AKV-Config-1 false vs1 AKV AWS-Config-1 true 4 entries were displayed.
The following example lists only the keystore configurations that are enabled.
Cluster-1::*> security key-manager keystore show -enabled true Vserver Keystore Type Config Name Enabled ---------------------- -------------- ------------------ ------- Cluster-1 OKM default true vs0 AKV default true vs1 AKV AWS-Config-1 true 3 entries were displayed.
 PDFs
PDFs
