ONTAP commands
security key-manager keystore show
Displays the configured key manager keystores.
This command displays all keystore configurations.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver
If you specify this parameter, then the command displays only the keystore configurations with the given Vserver.
[-keystore-type <Key Store Type>] - Keystore Type
If you specify this parameter, then the command displays only the keystore configurations with the given keystore type.
[-config-name <text>] - Configuration Name
If you specify this parameter, then the command displays only the keystore configurations with the given configuration name.
[-enabled {true|false}] - Configuration Is Enabled?
If you specify this parameter, then the command displays only the keystore configurations with the given enabled value.
[-uuid <UUID>] - Key Store UUID
If you specify this parameter, then the command displays only the keystore configuration with the given universal unique identifier (UUID) value.
[-state <Key Store state>] - Key Store State
If you specify this parameter, then the command displays only the keystores with the given state.
The following example lists all keystore configurations.
Cluster-1::*> security key-manager keystore show
Vserver                Keystore Type  Config Name        Enabled
Cluster-1              OKM            default            true
vs0                    AKV            default            true
vs0                    AKV            AKV-Config-1       false
vs1                    AKV            AWS-Config-1       true
4 entries were displayed.
The following example lists only the keystore configurations that are enabled.
Cluster-1::*> security key-manager keystore show -enabled true
3 entries were displayed.
