vserver iscsi security delete
Delete the iSCSI authentication configuration for an initiator
This command removes the security settings for this initiator. The default authentication setting now applies to this initiator.
-vserver <Vserver Name>- Vserver-
Specifies the Vserver.
-i, -initiator-name <text>- Initiator Name-
Specifies the initiator that you want to remove the authentication setting from.
cluster1::> vserver iscsi security delete -vserver vs1 -initiator-name iqn.1992-08.com.example:abcdefg
Deletes initiator iqn.1992-08.com.example:abcdefg on Vserver vs1 from the authentication setting. The default authentication now applies to this initiator.
