Command reference
cluster controller-replacement network displaced-interface delete
Delete network interfaces displaced away from this node by controller-replacement
Delete references to logical interfaces that were displaced to another node due to a controller-replacement. A LIF that has been displaced to another node has had its home-node modified to another node because no network ports were available in the same broadcast domain on the original home-node. Deleting this entry does not delete the LIF, it only deletes the entry from the displaced-lifs table indicating that the LIF's current home-node is considered restored.
-node <nodename> - Node
Selects the node from which the LIF was displaced.
-vserver <vserver> - Vserver
Selects the vserver on which the LIF resides.
-lif-name <text> - Lif Name
Selects the name of the LIF for which to display displaced information.
The following example deletes displaced LIF information.
cluster1::> cluster controller-replacement network displaced-interface delete -vserver vs0 -lif lif1
