security multi-admin-verify approval-group replace
Add and/or remove approvers from the list
The security multi-admin-verify approval-group replace
command is used to replace the list of approvers of an approval group.
-vserver <vserver>
- Vserver-
This specifies the Vserver name to which the approval group is associated with. This is an optional parameter. This parameter defaults to Cluster server and supports only Cluster servers.
-name <text>
- Group Name-
This specifies the name of the approval group whose approvers are to be replaced.
[-approvers-to-add <text>,…]
- New Approvers-
This specifies the list of ONTAP users that are to be added to the current list of approvers of the approval group.
[-approvers-to-remove <text>,…]
- Existing Approvers-
This specifies the list of ONTAP users that are to be removed from the current list of approvers of the approval group.
The following example adds user admin2 and removes user admin from the current approvers list, while group1 is associated with the default Vserver:
cluster1::> security multi-admin-verify approval-group replace -name group1 -approvers-to-add admin2 -approvers-to-remove admin.
