vserver nfs kerberos realm show
Display Kerberos realm configurations
The vserver nfs kerberos realm show
command displays information about Kerberos realm configurations. The command output depends on the parameters specified with the command. If you do not specify any parameters, the command displays the following information about all Kerberos realm configurations:
Vserver
Kerberos realm name
Active Directory server name
Kerberos Distribution Center (KDC) vendor
KDC IP address
The permitted encryption types
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver-
If you specify this parameter, the command displays information only about the Kerberos realm configurations for the specified Vserver.
[-realm <text>]
- Kerberos Realm-
If you specify this parameter, the command displays information only about the Kerberos realm configurations that use the specified Kerberos realm.
[-kdc-vendor <Kerberos Key Distribution Center (KDC) Vendor>]
- KDC Vendor-
If you specify this parameter, the command displays information only about the Kerberos realm configurations that use the specified KDC vendor.
[-kdc-ip <IP Address>]
- KDC IP Address-
If you specify this parameter, the command displays information only about the Kerberos realm configurations that use the specified KDC IP address.
[-kdc-port <integer>]
- KDC Port-
If you specify this parameter, the command displays information only about the Kerberos realm configurations that use the specified KDC port number.
[-clock-skew <integer>]
- Clock Skew-
If you specify this parameter, the command displays information only about the Kerberos realm configurations that use the specified clock skew.
[-adserver-name <text>]
- Active Directory Server Name-
If you specify this parameter, the command displays information only about the Kerberos realm configurations that use the Active Directory server that has the specified name.
[-adserver-ip <IP Address>]
- Active Directory Server IP Address-
If you specify this parameter, the command displays information only about the Kerberos realm configurations that use the Active Directory server that has the specified IP address.
[-comment <text>]
- Comment-
If you specify this parameter, the command displays information only about the Kerberos realm configurations that match the specified comment text.
[-adminserver-ip <IP Address>]
- Admin Server IP Address-
If you specify this parameter, the command displays information only about the Kerberos realm configurations that use the specified administrative-server IP address.
[-adminserver-port <integer>]
- Admin Server Port-
If you specify this parameter, the command displays information only about the Kerberos realm configurations that use the specified administrative-server port number.
[-passwordserver-ip <IP Address>]
- Password Server IP Address-
If you specify this parameter, the command displays information only about the Kerberos realm configurations that use the specified password-server IP address.
[-passwordserver-port <integer>]
- Password Server Port-
If you specify this parameter, the command displays information only about the Kerberos realm configurations that use the specified password-server port number.
[-permitted-enc-types <NFS Kerberos Encryption Type>,…]
- Permitted Encryption Types-
If you specify this parameter, the command displays information only about the Kerberos realm configuration that match the specified encryption types.
The following example displays information about all Kerberos realm configurations:
cluster1::> vserver nfs kerberos realm show Kerberos Active Directory KDC KDC Vserver Realm Server Vendor IP Address -------- ------------------------ ---------------- ---------- ----------------- AUTH SEC.EXAMPLE.COM AUTH.SEC.EXAMPLE.COM Microsoft 192.0.2.170
