vserver peer accept
Accept a pending Vserver peer relationship
The vserver peer accept
command is used to accept the Vserver peer relationship between two Vservers. This command is used only for intercluster Vserver peer relationships.
-vserver <vserver>
- Vserver Name-
Specifies name of the local Vserver for which you want to accept the Vserver peer relationship.
-peer-vserver <vserver>
- Peer Vserver Name-
Specifies name of the peer Vserver with which the Vserver peer relationship was initiated.
[-local-name <vserver>]
- Peer Vserver Local Name-
Specifies the unique local name to identify the peer Vserver with which the Vserver peer relationship was initiated. The default value is the remote peer Vserver name.
The following example illustrates how to accept the Vserver peer relationship between Vservers pvs1.example.com
residing on cluster2
, and lvs1.example.com
residing on cluster1
cluster2::> vserver peer accept -vserver pvs1.example.com -peer-vserver lvs1.example.com
, and pvs1.example.com
. During execution of vserver peer create command on peer cluster, peer Vserver name is locally refered by unique system generated name pvs1.example.com.1
. Using vserver peer accept
command specify the unique -local-name
for peer Vserver.
cluster2::> vserver peer accept -vserver pvs1.example.com -peer-vserver pvs1.example.com.1 -local-name locallyUniqueName
