cluster controller-replacement network displaced-vlans delete
Remove VLANs displaces by controller-replacement
Delete VLAN tags that were displaced due to a controller-replacement. A VLAN tag that has been displaced is a tag that was based on a network port that either no longer exists, or was moved to a new broadcast domain. Restoring the vlan-tags re-creates them on the specified network port.
-node <nodename>
- Node-
Selects the node on which the displaced vlans reside.
-port <netport>
- Original Base Port-
The original base port where the vlans existed prior to controller-replacement.
The following example deletes the displaced vlan-tag information.
cluster1::> cluster controller-replacement network displaced-vlans delete -node local -port e0c
