ONTAP commands
vserver object-store-server bucket lifecycle-management-rule create
Create a lifecycle management rule
The vserver object-store-server bucket lifecycle-management-rule create command creates a lifecycle management rule for the object store server bucket.
-vserver <Vserver Name> - Vserver Name
This parameter specifies the name of the Vserver on which the bucket lifecycle management rule needs to be created for the object store server bucket.
-bucket <TextNoCase> - Object Store Server Bucket Name
This parameter specifies the name of the object store server bucket for which the lifecycle management rule needs to be created. The object store server bucket must already exist.
-rule-id <text> - Lifecycle Management Rule Identifier
This parameter specifies the rule identifier of the lifecycle management rule to be applied on the object store server bucket.
[-index <integer>] - Lifecycle Management Rule Index
This parameter specifies the index of the lifecycle management rule to be applied on the object store server bucket.
[-is-enabled {true|false}] - Is This Rule Enabled?
This parameter specifies whether the configured lifecycle management rule is enabled or disabled on the object store server bucket. If you do not specify this parameter, the default is true .
[-prefix <text>] - Prefix to be Matched with Object Names
Use this parameter to specify a prefix that is matched against object-names within a bucket.
[-tags <text>,…​] - Tags in Format <tag> or <tag=value>
Use this parameter to specify a list of key-value paired tags.
[-obj-size-greater-than {<integer>[KB|MB|GB|TB|PB]}] - Min Size of the Object
Use this parameter to specify the minimum size of the object for which the corresponding lifecycle rule is to be applied.
[-obj-size-less-than {<integer>[KB|MB|GB|TB|PB]}] - Max Size of the Object
Use this parameter to specify the maximum size of the object for which the corresponding lifecycle rule is to be applied.
-action {Expiration|NoncurrentVersionExpiration|AbortIncompleteMultipartUpload} - Lifecycle Management Action
Use this parameter to specify lifecycle management actions. The set of actions that the object store server supports are Expiration , NoncurrentVersionExpiration and AbortIncompleteMultipartUpload .
{ [-obj-age-days <integer>] - Number of Days since Creation, After Which Current Version of Objects Can be Deleted
Minimum lifetime in number of days since creation, after which objects can be deleted. This parameter is available for expiration actions only.
[-obj-exp-date <MM/DD/YYYY HH:MM:SS>] - Specific Date When the Objects Should Expire
Expiration date of an object. This parameter is available for expiration actions only.
[-expired-obj-del-marker {true|false}] - Cleanup Object Delete Markers
When set to true , an object with a delete marker will be deleted. This parameter is available for expiration actions only.
| [-new-non-curr-versions <integer>] - Number of Latest Non-current Versions to Be Retained
This parameter specifies the number of latest non-current versions to be retained. This parameter is available for non-current version expiration actions only.
[-non-curr-days <integer>] - Number of Days after Which Non-current Versions will Be Deleted
This parameter specifies the number of days after which non-current versions can be deleted. This parameter is available for non-current version expiration actions only.
| [-after-initiation-days <integer>] - Number of Days of Initiation, After Which Upload Can Be Aborted }
This parameter specifies the number of days of initiation, after which uploads can be aborted. This parameter is required for abort-incomplete multipart upload actions only.
The following example creates an object store server bucket lifecycle management rule for Vserver vs1 and bucket1 which specifies an expiration action on a set of objects.
cluster1::> vserver object-store-server bucket lifecycle-management-rule create -vserver vs1 -bucket bucket1 -rule-id rule1 -prefix obj1/ -action Expiration -obj-age-days 100"
