ONTAP commands
security dynamic-authorization group modify
Modify a Dynamic Authorization group
The security dynamic-authorization group modify command modifies the dynamic authorization groups.
-vserver <vserver name> - Vserver
This parameter optionally specifies the Vserver of the group for which the -excluded-usernames or -comment is being modified. If this parameter is specified, the setting applies to that Vserver only. If not specified, the cluster Vserver setting is used.
-name <text> - Group Name
This parameter specifies the name of the group for which the -excluded-usernames or -comment is being modified.
[-excluded-usernames <text>,…​] - List of Excluded Users
This parameter specifies the list of users to be excluded from dynamic authorization.
[-comment <text>] - Comment
This parameter optionally specifies the comments.
The following command modifies the excluded users for the group test who is part of Vserver vs1 .
cluster1::> security dynamic-authorization group modify -vserver vs1 -group-name test -excluded-usernames Jsmith
