network arp active-entry show
Display active ARP entries organized by Vserver
The `network arp active-entry show ` command displays ARP entries present in the network stack of the node. The entries includes both dynamically learned ARP entries and user configured static ARP entries.
[-fields <fieldname>,…]
Use this parameter to display only certain fields of the active ARP table.
[-instance ]
Use this parameter to display all the fields of the active ARP table.
[-node {<nodename>|local}]
- Node (privilege: advanced)-
Use this parameter to display active ARP entries that are specific to a given node.
[-vserver <vserver>]
- System or Admin Vserver Name (privilege: advanced)-
Use this parameter to display active ARP entries that are specific to a given System or Admin Vserver. Data and Node Vservers will not have any active-arp entries.
[-subnet-group <IP Address/Mask>]
- Subnet Group Name (privilege: advanced)-
Use this parameter to display active ARP entries that are specific to a given subnet group.
[-remotehost <text>]
- Remote IP Address (privilege: advanced)-
Use this parameter to display active ARP entries for the specified IP address.
[-port <text>]
- Port (privilege: advanced)-
Use this parameter to display active ARP entries for the specified Port name.
[-mac <text>]
- MAC Address (privilege: advanced)-
Use this parameter to display the active ARP entry for the specified MAC address.
[-ipspace <IPspace>]
- IPspace (privilege: advanced)-
Use this parameter to specify the IPspace associated with the System or Admin Vserver.
The following example displays active ARP entries for the Admin Vserver cluster1:
cluster1::*> network arp active-entry show -vserver cluster1 Node: node-01 Vserver: cluster1 Subnet Group: 169.254.0.0/16 Remote IP Address MAC Address Port ----------------- ----------------- ------- 169.254.106.95 0:55:39:27:d1:c1 lo
