ONTAP commands
network arp active-entry show
Display active ARP entries organized by Vserver
The `network arp active-entry show ` command displays ARP entries present in the network stack of the node. The entries includes both dynamically learned ARP entries and user configured static ARP entries.
[-fields <fieldname>,…​]
Use this parameter to display only certain fields of the active ARP table.
| [-instance ] (privilege: advanced) }
Use this parameter to display all the fields of the active ARP table.
[-node {<nodename>|local}] - Node (privilege: advanced)
Use this parameter to display active ARP entries that are specific to a given node.
[-vserver <vserver>] - System or Admin Vserver Name (privilege: advanced)
Use this parameter to display active ARP entries that are specific to a given System or Admin Vserver. Data and Node Vservers will not have any active-arp entries.
[-subnet-group <IP Address/Mask>] - Subnet Group Name (privilege: advanced)
Use this parameter to display active ARP entries that are specific to a given subnet group.
[-remotehost <text>] - Remote IP Address (privilege: advanced)
Use this parameter to display active ARP entries for the specified IP address.
[-port <text>] - Port (privilege: advanced)
Use this parameter to display active ARP entries for the specified Port name.
[-mac <text>] - MAC Address (privilege: advanced)
Use this parameter to display the active ARP entry for the specified MAC address.
[-ipspace <IPspace>] - IPspace (privilege: advanced)
Use this parameter to specify the IPspace associated with the System or Admin Vserver.
The following example displays active ARP entries for the Admin Vserver cluster1:
cluster1::*> network arp active-entry show -vserver cluster1
Node: node-01
Vserver: cluster1
Subnet Group: 169.254.0.0/16
Remote IP Address MAC Address       Port
169.254.106.95    0:55:39:27:d1:c1  lo
