      vserver cifs symlink delete
Delete a symlink path mapping
The vserver cifs symlink delete command deletes a symbolic link mapping for CIFS.
-vserver <vserver name>- Vserver-
This specifies the Vserver on which the symbolic link mapping is located.
 -unix-path <text>- UNIX Path-
This specifies the UNIX (NFS) path of the mapping that you want to delete.
The following example deletes a symbolic link mapping to a UNIX path /example/ from a Vserver named vs1:
cluster1::> vserver cifs symlink delete -vserver vs1 -unix-path /example/
