vserver export-policy copy
Copy an export policy
The vserver export-policy copy
command creates a copy of an export policy on the same or a different Vserver. The command fails if an export policy with the specified new name already exists on the target Vserver.
-vserver <vserver name>
- Vserver-
This parameter specifies the Vserver on which the export policy that you want to copy is located.
-policyname <export policy name>
- Policy Name-
This parameter specifies the export policy that you want to copy.
-newvserver <vserver name>
- New Vserver-
This parameter specifies the Vserver to which you want to copy the export policy.
-newpolicyname <export policy name>
- New Export Policy Name-
This parameter specifies the name of the new policy.
The following example copies an existing policy named read_only_expolicy located on a Vserver named vs0 to a new policy named default_expolicy located on a Vserver named vs1.
vs1::> vserver export-policy copy -vserver vs0 -policyname read_only_expolicy -newvserver vs1 -newpolicyname default_expolicy
