      volume efficiency stop
Stop efficiency operation on a volume
Use the volume efficiency stop command to stop an efficiency operation.
- -vserver <vserver name>- Vserver Name
This specifies the Vserver on which the volume is located.
- { -volume <volume name>- Volume Name
This specifies the name of the volume on which efficiency operation needs to be stopped.
- | -path </vol/volume>- Volume Path }
This specifies the volume path on which efficiency operation needs to be stopped.
- [-a, -all <true>]- Stop All Operations
This specifies both active and queued efficiency operations to be aborted.
The following examples stop efficiency on a volume.
cluster1::> volume efficiency stop -vserver vs1 -volume vol1
cluster1::> volume efficiency stop -vserver vs1 -volume vol1 -all
 PDFs
PDFs
