security login role show-ontapi
Display the mapping between Data ONTAP APIs and CLI commands
The security login role show-ontapi
command displays Data ONTAP APIs (ONTAPIs) and the CLI commands that they are mapped to.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-ontapi <text>]
- ONTAPI Name-
Use this parameter to view the corresponding CLI command for the specified API.
[-command <text>]
- CLI Command-
Use this parameter to view the corresponding API or APIs for the specified CLI command.
The following command displays all Data ONTAP APIs and their mapped CLI commands:
cluster1::> security login role show-ontapi ONTAPI Command --------------------------- --------------------------------------------------- aggr-add storage aggregate add-disks aggr-check-spare-low storage aggregate check_spare_low aggr-create storage aggregate create aggr-destroy storage aggregate delete aggr-get-filer-info aggr aggr-get-iter storage aggregate show-view aggr-offline storage aggregate offline aggr-online storage aggregate online aggr-options-list-info storage aggregate show aggr-rename storage aggregate rename aggr-restrict storage aggregate restrict aggr-set-option storage aggregate modify autosupport-budget-get system node autosupport budget show autosupport-budget-get-iter system node autosupport budget show autosupport-budget-get-total-records system node autosupport budget show autosupport-budget-modify system node autosupport budget modify autosupport-config-get system node autosupport show autosupport-config-get-iter system node autosupport show autosupport-config-get-total-records system node autosupport show autosupport-config-modify system node autosupport modify Press <space> to page down, <return> for next line, or 'q' to quit...
The following example displays all Data ONTAP APIs which are mapped to the specified CLI command:
cluster1::> security login role show-ontapi -command version ONTAPI Command --------------------------- --------------------------------------------------- system-get-ontapi-version version system-get-version version 2 entries were displayed.
The following example displays the CLI command that is mapped to the specified Data ONTAPI API:
cluster1::> security login role show-ontapi -ontapi aggr-create ONTAPI Name: aggr-create Command: storage aggregate create
