vserver fpolicy show-enabled
Display all enabled policies
The vserver fpolicy show-enabled
command displays information about all enabled policies in the Vserver. The command output depends on the parameter or parameters specified with the command. If you do not specify any parameters, the command displays the following information about all FPolicy policies:
Vserver name
Policy name
Priority
You can specify the -fields
parameter to specify which fields of information to display about FPolicy policies.
You can specify the -instance
parameter to display information for all FPolicy policies in a list format.
[-fields <fieldname>,…]
If you specify the -fields <fieldname>, … parameter, the command only displays the fields that you specify.
[-instance ]
If you specify the -instance parameter, the command displays detailed information about all entries.
[-vserver <vserver>]
- Vserver-
If you specify this parameter, the command displays information only about the FPolicy policies for the specified Vserver.
[-policy-name <Policy name>]
- Policy Name-
If you specify this parameter, the command displays information only about the FPolicy policy that you specify.
[-priority <text>]
- Policy Priority-
If you specify this parameter, the command displays information only about the FPolicy policies with the policy priority that you specify.
The following example displays the information about enabled FPolicy policies on the cluster.
cluster1::> vserver fpolicy show-enabled Vserver Policy Name Priority ----------------------- ------------------------------ ---------- vs1.example.com pol_native native vs1.example.com pol_native2 native vs1.example.com pol1 2 vs1.example.com pol2 4
