network ndp prefix show
Display IPv6 prefixes
The network ndp prefix show
command displays IPv6 prefixes on one or more nodes.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-verbose ]
(privilege: advanced) -
Displays the valid-lifetime, preferred-lifetime, origin and advertising-router fields.
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node (privilege: advanced)-
Displays the IPv6 prefixes from the specified node.
[-ipspace <IPspace>]
- IPspace name (privilege: advanced)-
Displays the IPv6 prefixes from the specified IPspace.
[-port {<netport>|<ifgrp>}]
- Port (privilege: advanced)-
Displays the IPv6 prefixes on the specified port.
[-prefix <IP Address/Mask>]
- Prefix (privilege: advanced)-
Displays the IPv6 prefixes with the specified prefix value.
[-flag {none|on-link|autonomous|on-link-autonomous}]
- Flag (privilege: advanced)-
Displays the IPv6 prefixes with the specified flag. The flag indicates whether a prefix is on-link and whether it can be used in autonomous address configuration.
[-valid-lifetime {<unsigned integer>|infinity}]
- Valid Lifetime (privilege: advanced)-
Displays the IPv6 prefixes having the specified valid lifetime in seconds.
[-preferred-lifetime {<unsigned integer>|infinity}]
- Preferred Lifetime (privilege: advanced)-
Displays the IPv6 prefixes having the specified preferred lifetime in seconds.
[-expire-time {[<integer>d][<integer>h][<integer>m][<integer>s]|never|expired}]
- Expire Time (privilege: advanced)-
Displays the IPv6 prefixes having the specified expire time.
[-origin {router-advertise|renumber-request|static|kernel|unknown}]
- Origin of the Prefix (privilege: advanced)-
Displays the IPv6 prefixes with the specified origin.
[-advertising-router <IP Address>,…]
- Router that Advertised the Prefix (privilege: advanced)-
Displays the IPv6 prefixes which are propagated by the specified router list.
The following example displays IPv6 prefixes on port e0f.
cluster1::*> network ndp prefix show -port e0f -node local Node: node1 IPspace: Default Port Prefix Flag Expire Time --------- ------------------------- ------------------ ------------- e0f fd20:8b1e:b255:814e::/64 on-link-autonomous 29d23h56m48s
