security multi-admin-verify rule show
Display rules
The security multi-admin-verify rule show command displays information about multi admin verification rules.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <vserver>]- Vserver
This specifies the Vserver information to which the rule is associated with. This is an optional parameter. This parameter defaults to a Cluster server and supports only Cluster servers.
- [-operation <text>]- Operation
This specifies the ONTAP operation information for which the rule is created.
- [-auto-request-create {true|false}]- Automatic Request Creation
This specifies the information of the auto request create state for the rule.
- [-query <query>]- Query
This specifies the query information which is applied to the subset of objects of ONTAP operation of the rule.
- [-required-approvers {<integer>|-}]- Required Number of Approvers
This specifies the number of approvers that are required to approve the ONTAP execution request.
- [-approval-groups <text>,…]- Approval Groups
This specifies the list of approval groups that lists the users who can approve the ONTAP execution request.
- [-execution-expiry <[<integer>d][<integer>h][<integer>m][<integer>s]>]- Execution Expiry
This specifies the amount of time that the authorized users have after a request is approved to execute the requested operation before the request expires.
- [-approval-expiry <[<integer>d][<integer>h][<integer>m][<integer>s]>]- Approval Expiry
This is the amount of time that the approvers have after a new execution request is submitted to approve or disapprove the request before the request expires.
- [-time-created <MM/DD/YYYY HH:MM:SS>]- Time Created
This specifies the time at which the rule is created.
- [-system-defined {true|false}]- Is System Defined
Displays the value true if rule is defined by the system. Displays the value false if rule is defined by the user.
The following example displays typical rule information:
cluster1::> security multi-admin-verify rule show
                                                           Required  Approval
    Vserver     Operation                                  Approvers Groups
    cluster1
                security login password                    1         -
                  Query: -multi-admin-approver true -different-user true
                security multi-admin-verify approval-group create
                                                           1         -
                security multi-admin-verify approval-group delete
                                                           1         -
                security multi-admin-verify approval-group modify
                                                           1         -
                security multi-admin-verify approval-group replace
                                                           1         -
                security multi-admin-verify modify         1         -
                security multi-admin-verify rule create    1         -
                security multi-admin-verify rule delete    1         -
                security multi-admin-verify rule modify    1         -
                volume delete                              3         -
                  Query: -vserver vs0
    10 entries were displayed.
 PDFs
PDFs
