security session kill-cli
Kill a CLI session
The security session kill-cli
command is used to terminate CLI sessions. If the session being killed is actively processing a non-read command, the kill will wait until the command is complete before terminating the session. If the session being killed is actively processing a read (show) command, the kill will wait until the current row is returned before terminating the session.
-node {<nodename>|local}
- Node-
Selects the sessions that match this parameter value. This identifies the node that is processing the session.
[-interface {cli|ontapi|rest}]
- Interface-
Selects the sessions that match this parameter value. This identifies the interface (CLI, ONTAPI, or REST) that is processing the session.
[-start-time <MM/DD HH:MM:SS>]
- Start Time-
Selects the sessions that match this parameter value. This identifies the start time of the current active session.
-session-id <integer>
- Session ID-
Selects the sessions that match this parameter value. This number uniquely identifies a management session within a given node.
[-vserver <vserver>]
- Vserver-
Selects the sessions that match this parameter value. This identifies the Vserver associated with this management session.
[-username <text>]
- Username-
Selects the sessions that match this parameter value. This identifies the authenticated user associated with this management session.
[-application <text>]
- Client Application-
Selects the sessions that match this parameter value. This identifies the calling application by name.
[-location <text>]
- Client Location-
Selects the sessions that match this parameter value. This identifies the location of the calling client application. This is typically the IP address of the calling client, or "console" or "localhost" for console or localhost connections.
[-idle-seconds <integer>]
- Idle Seconds-
Selects the sessions that match this parameter value. When a session is not actively executing a command request (the session is idle), this indicates the time (in seconds) since the last request completed.
[-state {pending|active|idle}]
- Session State-
Selects the sessions that match this parameter value. This identifies the state (pending, active, or idle) of the session. The state is "pending" if it hit a session limit and the session is waiting for another session to end. The state is "idle" for CLI sessions that are waiting at the command prompt. The state is "active" if the session is actively working on a request.
[-request <text>]
- Active Command-
Selects the sessions that match this parameter value. This identifies the request (command) that is currently being handled by the session.
The following example illustrates killing a CLI session by specifying the node and the session id.
cluster1::> security session show -node node1 Node: node1 Interface: cli Idle Start Time Sess ID Application Location Vserver Username Seconds -------------- ------- ----------- ------------ ------------- -------- -------- 03/27 16:58:13 1358 console console cluster1 admin - Active Seconds: 0 Request: security session show 03/27 16:58:17 1359 ssh 10.98.16.164 cluster1 admin 650 2 entries were displayed. cluster1::> cluster1::> security session kill-cli -node node1 -session-id 1359 1 entry was acted on. cluster1::> security session show -node node1 Node: node1 Interface: cli Idle Start Time Sess ID Application Location Vserver Username Seconds -------------- ------- ----------- ------------ ------------- -------- -------- 03/27 16:58:13 1358 console console cluster1 admin - Active Seconds: 0 Request: security session show cluster1::>
The following example illustrates killing a CLI session by specifying the node and specifying a query on idle-seconds.
cluster1::> security session show -node node1 Node: node1 Interface: cli Idle Start Time Sess ID Application Location Vserver Username Seconds -------------- ------- ----------- ------------ ------------- -------- -------- 03/27 16:58:13 1358 console console cluster1 admin - Active Seconds: 0 Request: security session show 03/27 17:13:36 1479 ssh 10.98.16.164 cluster1 admin 83 2 entries were displayed. cluster1::> security session kill-cli -node node1 -session-id * -idle-seconds > 80 1 entry was acted on. cluster1::> security session show Node: node1 Interface: cli Idle Start Time Sess ID Application Location Vserver Username Seconds -------------- ------- ----------- ------------ ------------- -------- -------- 03/27 16:58:13 1358 console console cluster1 admin - Active Seconds: 0 Request: security session show cluster1::>
