storage aggregate object-store mirror
Attaches a second object store to a FabricPool aggregate to create a mirror
The storage aggregate object-store mirror
command attaches a second object store to a FabricPool aggregate to create a mirror. This command verifies whether the object store is accessible through the intercluster LIF from both the node on which the aggregate is present and from its high-availability (HA) partner node. The command fails if the object store is not accessible.
-aggregate <text>
- Name of the Aggregate-
This parameter specifies the aggregate to which the object store must be attached in order to create a mirror.
-object-store-name <text>
- Object Store Configuration Name-
This parameter specifies the name of the new object store configuration to be attached to the aggregate. The object store configuration has information about the object store server name, port, access credentials, and provider type.
The following example shows how to create a mirror to aggregate aggr1:
cluster1::>storage aggregate object-store mirror -aggregate aggr1 -object-store-name my-store-2
