security key-manager health policy modify
Modify the health monitor policy of the given keystore-type
This command modifies the health monitor policy
-keystore-type <Key Store Type>- Keystore Type-
Use this parameter to specify the keystore-type of the health monitor policy to be updated.
[-enabled {true|false}]- Health Monitor Enabled?-
Use this parameter to specify if the health monitor is enabled.
[-manage-volume-offline {true|false}]- Automatically Manage Volume Offline?-
Use this parameter to specify if the health monitor can automatically offline the volumes if the key manager cannot be reached.
The following example updates the AWS 'keystore-type' health monitor policy "enabled" and "manage-volume-offline" values.
cluster-1::> security key-manager health policy modify -keystore-type AWS -enabled false -manage-volume-offline false
