security key-manager health policy modify
Modify the health monitor policy of the given keystore-type
This command modifies the health monitor policy
- -keystore-type <Key Store Type>- Keystore Type
Use this parameter to specify the keystore-type of the health monitor policy to be updated.
- [-enabled {true|false}]- Health Monitor Enabled?
Use this parameter to specify if the health monitor is enabled.
- [-manage-volume-offline {true|false}]- Automatically Manage Volume Offline?
Use this parameter to specify if the health monitor can automatically offline the volumes if the key manager cannot be reached.
The following example updates the AWS 'keystore-type' health monitor policy "enabled" and "manage-volume-offline" values.
cluster-1::> security key-manager health policy modify -keystore-type AWS -enabled false -manage-volume-offline false
 PDFs
PDFs
