system configuration recovery cluster rejoin
Rejoin a cluster
The system configuration recovery cluster rejoin
command rejoins a node to a new cluster created earlier using the system configuration recovery cluster recreate command. Only use this command to recover a node from a disaster. Because this synchronization can overwrite critical cluster information, and will restart the node you specify, you are required to confirm this command before it executes.
-node {<nodename>|local}
- Node to Rejoin (privilege: advanced)-
Use this parameter to specify the node to rejoin to the cluster.
This example shows how to rejoin the node node2
to the cluster.
cluster1::*> system configuration recovery cluster rejoin -node node2 Warning: This command will rejoin node "node2" into the local cluster, potentially overwriting critical cluster configuration files. This command should only be used to recover from a disaster. Do not perform any other recovery operations while this operation is in progress. This command will cause node "node2" to reboot. Do you want to continue? {y|n}: y
