metrocluster config-replication resync-status show
Display MetroCluster Configuration Resynchronization Status
The metrocluster config-replication resync-status show
command displays the state of the configuration synchronization operation between the two clusters in the MetroCluster configuration.
This command displays the following details about the local cluster and the peer cluster:
Source: This is the source side whose configuration is being replicated to the destination side.
Destination: This is the destination side where the configuration is being replicated to from the source side.
State: This is the state of the synchronization operation.
% Complete: This is completion percentage of the operation.
The following example shows the output of the command when synchronization is in progress:
clusterA::> metrocluster config-replication resync-status show Source Destination State % Complete ----------------------- ----------------------- ----------- ---------- clusterA clusterB complete - clusterB clusterA complete -
The following example shows the output of the command when synchronization from clusB to clusA is in progress:
clusA::> metrocluster config-replication resync-status show Source Destination State % Complete ----------------------- ----------------------- ----------- ---------- clusterA clusterB complete - clusterB clusterA messaging 95
