system node autosupport show
Display AutoSupport configuration
The system node autosupport show command displays the AutoSupport configuration of one or more nodes.
[-fields <fieldname>,…] -
If you specify the
[-config ] -
Use this parameter to display the retry interval, retry count, throttle, and reminder settings of all nodes in the cluster.
[-recent ] -
Use this parameter to display the subject and time of the last AutoSupport message generated by each node in the cluster.
[-support-http ] -
Use this parameter to display whether HTTP support is enabled in the cluster, and identify the transport protocol and the support proxy URL used.
[-support-smtp ] -
Use this parameter to display whether SMTP (e-mail) support is enabled in the cluster, and identify the transport protocol and the "to" e-mail address used.
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
The AutoSupport configuration is identical for all nodes in the cluster. Use this parameter to display detailed information about the node you specify.
[-state {enable|disable}]- State-
Use this parameter to display information only about nodes that have the AutoSupport state you specify.
[-mail-hosts <text>,…]- SMTP Mail Hosts-
Use this parameter to display information only about nodes that use the mail hosts you specify.
[-from <mail address>]- From Address-
Use this parameter to display information only about nodes that have the "from" e-mail address you specify.
[-to <mail address>,…]- List of To Addresses-
Use this parameter to display information only about nodes that have the "to" e-mail addresses you specify.
[-noteto <mail address>,…]- (DEPRECATED) List of Noteto Addresses-
This parameter has been deprecated and might be removed in a future version of Data ONTAP. Use this parameter to display information only about nodes that send short-note e-mail messages to the e-mail addresses you specify. Short-note e-mails contain only the subject line of the AutoSupport message, which is easier to view on a mobile device.
[-partner-address <mail address>,…]- List of Partner Addresses-
Use this parameter to display information only about nodes that have the "partner-address" e-mail addresses you specify. These addresses are not subject to the delivery limitations configured for the "-to" addresses of AutoSupport triggers.
[-support {enable|disable}]- Send AutoSupport Messages to Vendor Support-
Use this parameter with the value "enable" to display information only about nodes that send AutoSupport messages to your vendor's technical support. Use this parameter with the value "disable" to display information only about nodes that do not send AutoSupport messages to your vendor's technical support.
[-transport {smtp|https}]- Protocol to Contact Support-
Use this parameter to display information only about nodes that use the protocol you specify to send AutoSupport messages.
[-url <text>]- Support URL for HTTPS-
Use this parameter to display information only about nodes that use the URL you specify to send messages through the HTTPS POST operations.
[-put-url <text>]- Support URL for HTTPS PUT-
Use this parameter to display information only about nodes that use the URL you specify to send messages through the HTTPS PUT operations.
[-proxy-url <text>]- Support Proxy URL-
Use this parameter to display information only about nodes that use the proxy URL you specify.
[-support-address <mail address>,…]- Support Address-
Use this parameter to display information only about nodes that use the external support address you specify.
[-hostname-subj {true|false}]- Hostname Subject-
Use this parameter to display information only about nodes that include their hostname in the "Subject:" line of AutoSupport messages. If the parameter "remove-private-data" is
false, this parameter has no effect. [-perf {true|false}]- Performance Data Enable-
Use this parameter with the value "true" to display information only about nodes that send periodic performance AutoSupport messages. Use this parameter with the value "false" to display information only about nodes that do not send periodic performance messages.
[-retry-interval <[<integer>h][<integer>m][<integer>s]>]- Retry Interval-
Use this parameter to display information only about nodes that use the retry interval you specify.
[-retry-count <integer>]- Retry Count-
Use this parameter to display information only about nodes that use the retry count you specify.
[-reminder {true|false}]- Reminder Enable-
Use this parameter with the value "true" to display information only about nodes that send messages reminding administrators to enable AutoSupport if AutoSupport is not enabled. Use this parameter with the value "false" to display information only about nodes that do not send reminder messages.
[-last-subject <text>]- (DEPRECATED) Last Subject Sent-
This parameter has been deprecated and might be removed in a future version of Data ONTAP. Use this parameter to display information only about nodes whose last AutoSupport message had the "Subject:" line you specify.
[-last-time <MM/DD/YYYY HH:MM:SS>]- (DEPRECATED) Last Time Sent-
This parameter has been deprecated and might be removed in a future version of Data ONTAP. Use this parameter to display information only about nodes whose last AutoSupport message was sent at the date and time you specify. Specify the date and time in the format "MM/DD/YYYY HH:MM:SS".
[-max-http-size {<integer>[KB|MB|GB|TB|PB]}]- Maximum HTTPS Size-
Use this parameter to display information only about nodes that limit the maximum size of HTTP transfers to the file size you specify.
[-max-smtp-size {<integer>[KB|MB|GB|TB|PB]}]- Maximum SMTP Size-
Use this parameter to display information only about nodes that limit the maximum size of SMTP (e-mail) transfers to the file size you specify.
[-remove-private-data {true|false}]- Remove Sensitive Data-
Use this parameter with the value "true" to display information only about nodes that remove sensitive data from AutoSupport messages. Use this parameter with the value "false" to display information only about nodes that do not remove sensitive data.
[-validate-digital-certificate {true|false}]- Validate Digital Certificate Received (privilege: advanced)-
Use this parameter with the value "true" to display information only about nodes that validate digital certificates they receive. Use this parameter with the value "false" to display information only about nodes that do not validate digital certificates.
[-ondemand-state {enable|disable}]- AutoSupport OnDemand State (privilege: advanced)-
Use this parameter to display information only about nodes that have the AutoSupport OnDemand state you specify.
[-ondemand-remote-diagnostics-state {enable|disable}]- AutoSupport OnDemand Remote Diagnostics State (privilege: advanced)-
Use this parameter to display information only about nodes that have the AutoSupport OnDemand Remote Diagnostics state you specify.
[-ondemand-server-url <text>]- AutoSupport OnDemand Server URL-
Use this parameter to display information only about nodes that have the AutoSupport OnDemand Server URL you specify.
[-node-specific-from {enable|disable}]- Node-Specific From Address (privilege: advanced)-
Use this parameter to display information that matches the specified value - enabled or disabled.
[-validate-smtp-certificate {true|false}]- Validate Certificate of SMTP Server (privilege: advanced)-
Use this parameter with the value "true" to display information only about nodes that validate certificates they receive from the SMTP server. Use this parameter with the value "false" to display information only about nodes that do not validate certificates from the SMTP server.
[-smtp-encryption {none|start_tls}]- SMTP Encryption-
Use this parameter to display information only about nodes that use the encryption protocol you specify to send SMTP AutoSupport messages.
The following example displays the AutoSupport configuration for a node named node3:
cluster1::> system node autosupport show -node node3
Node: node3
State: enable
SMTP Mail Hosts: smtp.example.com
From Address: alerts@example.com
List of To Addresses: support@example.com
List of Noteto Addresses: -
List of Partner Addresses: support@partner.com
Send AutoSupport Messages to Vendor Support: enable
Protocol to Contact Support: https
Support Proxy URL: support.proxy.example.com
Hostname Subject: true
Performance Data Enable: true
Retry Interval: 4m
Retry Count: 15
Reminder Enable: true
The Transmission Window: 1h
Last Subject Sent: WEEKLY
Last Time Sent: 3/1/2019 06:00:03
Maximum HTTP Size: 50MB
Maximum SMTP Size: 5MB
Remove Sensitive Data: false
Continue Local Collection while Disabled: true
SMTP Encryption: none
