system node autosupport show
Display AutoSupport configuration
The system node autosupport show command displays the AutoSupport configuration of one or more nodes.
{ [-fields <fieldname>,…​]
| [-config ]
Use this parameter to display the retry interval, retry count, throttle, and reminder settings of all nodes in the cluster.
| [-nht-performance ]
Use this parameter to display NHT and performance information about all nodes in the cluster.
| [-recent ]
Use this parameter to display the subject and time of the last AutoSupport message generated by each node in the cluster.
| [-support-http ]
Use this parameter to display whether HTTP support is enabled in the cluster, and identify the transport protocol and the support proxy URL used.
| [-support-smtp ]
Use this parameter to display whether SMTP (e-mail) support is enabled in the cluster, and identify the transport protocol and the "to" e-mail address used.
| [-instance ] }
[-node {<nodename>|local}] - Node
Note The AutoSupport configuration is identical for all nodes in the cluster.
Use this parameter to display detailed information about the node you specify.
[-state {enable|disable}] - State
Use this parameter to display information only about nodes that have the AutoSupport state you specify.
[-mail-hosts <text>,…​] - SMTP Mail Hosts
Use this parameter to display information only about nodes that use the mail hosts you specify.
[-from <mail address>] - From Address
Use this parameter to display information only about nodes that have the "from" e-mail address you specify.
[-to <mail address>,…​] - List of To Addresses
Use this parameter to display information only about nodes that have the "to" e-mail addresses you specify.
[-noteto <mail address>,…​] - (DEPRECATED) List of Noteto Addresses
Note This parameter has been deprecated and might be removed in a future version of Data ONTAP.
Use this parameter to display information only about nodes that send short-note e-mail messages to the e-mail addresses you specify. Short-note e-mails contain only the subject line of the AutoSupport message, which is easier to view on a mobile device.
[-partner-address <mail address>,…​] - List of Partner Addresses
Use this parameter to display information only about nodes that have the "partner-address" e-mail addresses you specify. These addresses are not subject to the delivery limitations configured for the "-to" addresses of AutoSupport triggers.
[-support {enable|disable}] - Send AutoSupport Messages to Vendor Support
Use this parameter with the value "enable" to display information only about nodes that send AutoSupport messages to your vendor's technical support. Use this parameter with the value "disable" to display information only about nodes that do not send AutoSupport messages to your vendor's technical support.
[-transport {smtp|http|https}] - Protocol to Contact Support
Use this parameter to display information only about nodes that use the protocol you specify to send AutoSupport messages.
[-url <text>] - Support URL for HTTP/HTTPS
Use this parameter to display information only about nodes that use the URL you specify to send messages through HTTP and HTTPS POST operations.
[-put-url <text>] - Support URL for HTTP/S PUT
Use this parameter to display information only about nodes that use the URL you specify to send messages through HTTP PUT operations.
[-proxy-url <text>] - Support Proxy URL
Use this parameter to display information only about nodes that use the proxy URL you specify.
[-support-address <mail address>,…​] - Support Address
Use this parameter to display information only about nodes that use the external support address you specify.
[-hostname-subj {true|false}] - Hostname Subject
Use this parameter to display information only about nodes that include their hostname in the "Subject:" line of AutoSupport messages. If the parameter "remove-private-data" is false , this parameter has no effect.
[-nht {true|false}] - NHT Enable
Use this parameter with the value "true" to display information only about nodes that send NHT disk drive data. Use this parameter with the value "false" to display information only about nodes that do not send NHT data.
[-perf {true|false}] - Performance Data Enable
Use this parameter with the value "true" to display information only about nodes that send periodic performance AutoSupport messages. Use this parameter with the value "false" to display information only about nodes that do not send periodic performance messages.
[-retry-interval <[<integer>h][<integer>m][<integer>s]>] - Retry Interval
Use this parameter to display information only about nodes that use the retry interval you specify.
[-retry-count <integer>] - Retry Count
Use this parameter to display information only about nodes that use the retry count you specify.
[-reminder {true|false}] - Reminder Enable
Use this parameter with the value "true" to display information only about nodes that send messages reminding administrators to enable AutoSupport if AutoSupport is not enabled. Use this parameter with the value "false" to display information only about nodes that do not send reminder messages.
[-last-subject <text>] - (DEPRECATED) Last Subject Sent
Use this parameter to display information only about nodes whose last AutoSupport message had the "Subject:" line you specify.
[-last-time <MM/DD/YYYY HH:MM:SS>] - (DEPRECATED) Last Time Sent
Use this parameter to display information only about nodes whose last AutoSupport message was sent at the date and time you specify. Specify the date and time in the format "MM/DD/YYYY HH:MM:SS".
[-max-http-size {<integer>[KB|MB|GB|TB|PB]}] - Maximum HTTP Size
Use this parameter to display information only about nodes that limit the maximum size of HTTP transfers to the file size you specify.
[-max-smtp-size {<integer>[KB|MB|GB|TB|PB]}] - Maximum SMTP Size
Use this parameter to display information only about nodes that limit the maximum size of SMTP (e-mail) transfers to the file size you specify.
[-remove-private-data {true|false}] - Remove Sensitive Data
Use this parameter with the value "true" to display information only about nodes that remove sensitive data from AutoSupport messages. Use this parameter with the value "false" to display information only about nodes that do not remove sensitive data.
[-validate-digital-certificate {true|false}] - Validate Digital Certificate Received
Use this parameter with the value "true" to display information only about nodes that validate digital certificates they receive. Use this parameter with the value "false" to display information only about nodes that do not validate digital certificates.
[-ondemand-state {enable|disable}] - AutoSupport OnDemand State (privilege: advanced)
Use this parameter to display information only about nodes that have the AutoSupport OnDemand state you specify.
[-ondemand-remote-diagnostics-state {enable|disable}] - AutoSupport OnDemand Remote Diagnostics State (privilege: advanced)
Use this parameter to display information only about nodes that have the AutoSupport OnDemand Remote Diagnostics state you specify.
[-ondemand-server-url <text>] - AutoSupport OnDemand Server URL
Use this parameter to display information only about nodes that have the AutoSupport OnDemand Server URL you specify.
[-node-specific-from {enable|disable}] - Node-Specific From Address (privilege: advanced)
Use this parameter to display information that matches the specified value - enabled or disabled.
The following example displays the AutoSupport configuration for a node named node3:
cluster1::> system node autosupport show -node node3
                                       Node: node3
                                      State: enable
                            SMTP Mail Hosts: smtp.example.com
                               From Address: alerts@example.com
                       List of To Addresses: support@example.com
                   List of Noteto Addresses: -
                  List of Partner Addresses: support@partner.com
Send AutoSupport Messages to Vendor Support: enable
                Protocol to Contact Support: https
                          Support Proxy URL: support.proxy.example.com
                           Hostname Subject: true
                                 NHT Enable: true
                    Performance Data Enable: true
                             Retry Interval: 4m
                                Retry Count: 15
                            Reminder Enable: true
                    The Transmission Window: 1h
                          Last Subject Sent: WEEKLY
                             Last Time Sent: 3/1/2019 06:00:03
                          Maximum HTTP Size: 50MB
                          Maximum SMTP Size: 5MB
                      Remove Sensitive Data: false
      Validate Digital Certificate Received: true
   Continue Local Collection while Disabled: true
