system node autosupport history cancel
Cancel an AutoSupport Transmission.
The system node autosupport history cancel
command cancels an active AutoSupport transmission. This command is used to pause or abandon a long running delivery of an AutoSupport message. The cancelled AutoSupport message remains available for retransmission using the system node autosupport history retransmit command.
-node {<nodename>|local}
- Node-
Use this parameter to specify the node on which to cancel the AutoSupport message. The default setting is localhost.
-seq-num <Sequence Number>
- AutoSupport Sequence Number-
Use this parameter to specify the sequence number of the AutoSupport message you want to cancel.
[-destination {smtp|http|noteto|retransmit}]
- Destination for This AutoSupport-
Use this parameter to specify the destination type for the AutoSupport message you want to cancel.
Use this command to cancel the AutoSupport message delivery with seq-num 10 to all destinations.
cluster1::> system node autosupport history cancel -node local -seq-num 10
Use this command to cancel the AutoSupport message delivery with seq-num 10 via HTTP only.
cluster1::> system node autosupport history cancel -node local -seq-num 10 -destination http
