system node autosupport history cancel
Cancel an AutoSupport Transmission.
The system node autosupport history cancel command cancels an active AutoSupport transmission. This command is used to pause or abandon a long running delivery of an AutoSupport message. The cancelled AutoSupport message remains available for retransmission using the system node autosupport history retransmit command.
- -node {<nodename>|local}- Node
Use this parameter to specify the node on which to cancel the AutoSupport message. The default setting is localhost.
- -seq-num <Sequence Number>- AutoSupport Sequence Number
Use this parameter to specify the sequence number of the AutoSupport message you want to cancel.
- [-destination {smtp|http|noteto|retransmit}]- Destination for This AutoSupport
Use this parameter to specify the destination type for the AutoSupport message you want to cancel.
Use this command to cancel the AutoSupport message delivery with seq-num 10 to all destinations.
cluster1::> system node autosupport history cancel -node local -seq-num 10
Use this command to cancel the AutoSupport message delivery with seq-num 10 via HTTP only.
cluster1::> system node autosupport history cancel -node local -seq-num 10 -destination http
 PDFs
PDFs
