snapmirror mediator add
Create mediator config entry
The snapmirror mediator add command configures the connection between a pair of clusters and an ONTAP Mediator. It is mandatory to initialize the ONTAP Mediator on one of the cluster peers before the SnapMirror active sync relation with policy type automated-failover performs a planned or an unplanned failover. You can initialize the ONTAP Mediator from either cluster. When you issue the ONTAP Mediator add command on one cluster, the ONTAP Mediator is automatically added on the other cluster.
-mediator-address <IP Address>- Mediator Ip Address-
Specifies the IP address of the mediator.
-peer-cluster <text>- Peer cluster-
Peer cluster with AutomatedFailOver SnapMirror relationships.
-username <text>- Username-
User account at the mediator.
[-port-number <integer>]- Port Number-
This optional parameter specifies the mediator service port number to communicate with the mediator. The port number must be in the range 1025 to 65535 inclusive. The default port number is 31784.
The following example configures the connection between a mediator and a pair of clusters.
clusA::> snapmirror mediator add -mediator-address 10.234.102.227 -peer-cluster clusB -username admin
Notice: Enter the mediator password.
Enter the password:
Enter the password again:
Info: [Job: 114] 'mediator add' job queued
