ONTAP commands
vserver nvme create
Create NVMe service configuration
The vserver nvme create command creates an NVMe service for a Vserver.
When you create the NVMe service on a Vserver, the Vserver must have only nvme in the allowed-protocols list.
When you create the NVMe service on a Vserver, the administrative status of the service is up by default.
-vserver <Vserver Name> - Vserver Name
Specifies the Vserver for the NVMe service.
[-status-admin {down|up}] - Administrative Status
Specifies the configured administrative status of a service.
[-mdns-service-discovery-enabled {true|false}] - Use Multicast DNS Service Discovery (privilege: advanced)
Specifies the configured mDNS service discovery status of a service. If you set this parameter to false , the Vserver will not advertise NVMe-IP LIFs over Multicast DNS. The default value is true .
cluster1::*> vserver nvme create -vserver vs_1
Creates an NVMe service on Vserver vs_1 .
