statistics catalog object show
Display the list of objects
This command displays the names and descriptions of objects from which you can obtain performance data. The displayed data is either node-specific or cluster-wide, depending on the objects specified.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-describe ]
(privilege: advanced) } -
Displays detailed information about each object, including privilege level.
[-object <text>]
- Object (privilege: advanced)-
Selects the objects for which you want to display information. If you do not specify this parameter, the command displays details for all of the objects.
[-privilege <text>]
- Privilege Level (privilege: advanced)-
Selects the objects that match this parameter value.
[-is-deprecated {true|false}]
- Is Object Deprecated (privilege: advanced)-
Selects the objects that are deprecated (true) or are not deprecated (false).
[-replaced-by <text>]
- Replaced By Object If Deprecated (privilege: advanced)-
Selects all deprecated objects that are replaced by the object provided to this parameter.
[-is-statistically-tracked {true|false}]
- Is Object Statistically Tracked (privilege: advanced)-
Specifies if the object is statistically tracked
[-description <text>]
- Description (privilege: advanced)-
The following example displays descriptions of all objects in the cluster:
cluster1::> statistics catalog object show aggregate CM object for exporting aggregate performance counters audit_ng CM object for exporting audit_ng performance counters cifs These counters report activity from both SMB and SMB2 revisions of the CIFS protocol. For information isolated to SMB, see the 'smb1' object. For SMB2, see the 'smb2' object. cifs:node These counters report activity from both SMB and SMB2 revisions of the CIFS protocol. For information isolated to SMB, see the 'smb1' object. For SMB2, see the 'smb2' object. cifs:vserver These counters report activity from both SMB and SMB2 revisions of the CIFS protocol. For information isolated to SMB, see the 'smb1' object. For SMB2, see the 'smb2' object. cluster_peer The cluster peer object contains peer counters. [...]
