snaplock legal-hold show
Show status of a legal-hold operation.
The snaplock legal-hold show
command displays the status of a legal-hold operation. Information about completed operations will be cleaned up after an hour of completion. Only a user with security login role vsadmin-snaplock
is allowed to perform this operation.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver Name-
If this parameter is specified, the command displays all legal-hold operations that match the specified Vserver.
[-operation-id <integer>]
- Operation ID-
If this parameter is specified, the command displays all legal-hold operations that match the specified operation ID.
[-volume <volume name>]
- Volume Name-
If this parameter is specified, the command displays all legal-hold operations that match the specified volume. The parameter specifies the volume on which legal-hold operation is running or has completed.
[-path <text>]
- Path-
If this parameter is specified, the command displays all legal-hold operations that match the specified path. The parameter specifies the path on which legal-hold operation is running or has completed.
[-litigation-name <text>]
- Litigation Name-
If this parameter is specified, the command displays all legal-hold operations that match the specified litigation name. The parameter specifies the legal-hold litigation name.
[-operation-type {unknown|begin|end|dump-files}]
- Operation Type-
If this parameter is specified, the command displays all legal-hold operations that match the specified operation type. The parameter specifies the type of legal-hold operation.
[-operation-status {Unknown|In-Progress|Failed|Aborting|Completed}]
- Operation Status-
If this parameter is specified, the command displays all legal-hold operations that match the specified operation status. The parameter specifies the status of legal-hold operation.
[-num-files-processed <integer>]
- Number of Files Processed-
If this parameter is specified, the command displays all legal-hold operations that match the specified number of files processed. The parameter specifies the number of files on which legal-hold operation was successful.
[-num-files-failed <integer>]
- Number of Files Failed-
If this parameter is specified, the command displays all legal-hold operations that match the specified number of files failed. The parameter specifies the number of files on which legal-hold operation failed.
[-num-files-skipped <integer>]
- Number of Files Skipped-
If this parameter is specified, the command displays all legal-hold operations that match the specified number of files skipped.
The parameter specifies the number of files on which legal-hold begin operation was skipped. The legal-hold begin operation is skipped on a file if it is already under hold for a given litigation or if it is a hard link to a file that is already under hold for a given litigation.
[-num-inodes-ignored <integer>]
- Number of Inodes Ignored-
If this parameter is specified, the command displays all legal-hold operations that match the specified number of inodes ignored. The parameter specifies the number of inodes on which the legal-hold operation was not attempted because they were not regular files.
[-status-details <text>]
- Status Details-
If this parameter is specified, the command displays all legal-hold operations that match the specified status details. The parameter specifies the status details of an legal-hold operation.
The following examples show the status of legal-hold operations for Vserver vs1
and volume slc_vol1
and the status of legal-hold operation for operation ID 16842786
respectively:
vs1::> snaplock legal-hold show -volume slc_vol1 Operation Operation Operation ID Vserver Volume Status ------------- --------------- --------- ------- --------- begin 16842784 vs1 slc_vol1 Completed begin 16842786 vs1 slc_vol1 Completed begin 16842788 vs1 slc_vol1 In-Progress dump-files 16842790 vs1 slc_vol1 Completed end 16842794 vs1 slc_vol1 Completed 5 entries were displayed. vs1::> snaplock legal-hold show -operation-id 16842786 Vserver: vs1 Volume: slc_vol1 Operation ID: 16842786 Litigation Name: litigation1 Path: / Operation Type: begin Status: Completed Number of Files Processed: 100 Number of Files Failed: 15 Number of Files Skipped: 20 Number of Inodes Ignored: 0 Status Details: No error
