snapmirror config-replication cluster-storage-configuration show
Display SnapMirror storage configuration information
The snapmirror config-replication cluster-storage-configuration show
command shows details of the configuration of the storage used for configuration replication.
The information displayed is the following:
Disallowed Aggregates - The list of storage aggregates that are configured as not allowed to host storage areas.
Auto-Repair - Displays
true
if the automatic repair of storage areas used by configuration replication is enabled. -
Auto-Recreate - Displays
true
if the automatic recreation of storage volumes used by configuration replication is enabled. -
Use Mirrored Aggregate - Displays
true
if storage areas for configuration replication are to be hosted on a mirrored aggregate.
The following is an example of the snapmirror config-replication cluster-storage-configuration show
command:
cluster1::*> snapmirror config-replication cluster-storage-configuration show Disallowed Aggregates: - Auto-Repair: true Auto-Recreate: true Use Mirrored Aggregate: true
