ONTAP commands
snapmirror config-replication cluster-storage-configuration show
Display SnapMirror storage configuration information
The snapmirror config-replication cluster-storage-configuration show command shows details of the configuration of the storage used for configuration replication.
The information displayed is the following:
  • Disallowed Aggregates - The list of storage aggregates that are configured as not allowed to host storage areas.
  • Auto-Repair - Displays true if the automatic repair of storage areas used by configuration replication is enabled.
  • Auto-Recreate - Displays true if the automatic recreation of storage volumes used by configuration replication is enabled.
  • Use Mirrored Aggregate - Displays true if storage areas for configuration replication are to be hosted on a mirrored aggregate.
The following is an example of the snapmirror config-replication cluster-storage-configuration show command:
cluster1::*> snapmirror config-replication cluster-storage-configuration show
Disallowed Aggregates: -
           Auto-Repair: true
         Auto-Recreate: true
Use Mirrored Aggregate: true
