statistics nfs show-nlm
(DEPRECATED)-Display NLM statistics
The statistics nfs show-nlm
command displays the following statistics about the Network Lock Manager (NLM) on each node in the cluster:
Result of the operations (success or failure)
Total number of null operations
Total number of test operations
Total number of lock operations
Total number of cancel operations
Total number of unlock operations
Total number of granted operations
Total number of share operations
Total number of unshare operations
Total number of nmlock operations
Total number of freeall operations
Total number of all the above operations
This command is designed to be used to analyze performance characteristics and to help diagnose issues.
This command requires an effective cluster version earlier than Data ONTAP 9.0. Data for nodes running Data ONTAP 9.0 or later is not collected, and will not be displayed. Use the statistics show`-object`nlm command instead.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node (privilege: advanced)-
If you specify this parameter, the command displays statistics only for the specified node.
[-result {success|failure|all}]
- Result (privilege: advanced)-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified result (success/failure/all).
[-null <Counter with Delta>]
- Null Operations (privilege: advanced)-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of null operations.
[-test <Counter with Delta>]
- Test Operations (privilege: advanced)-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of test operations.
[-lock <Counter with Delta>]
- Lock Operations (privilege: advanced)-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of lock operations.
[-cancel <Counter with Delta>]
- Cancel Operations (privilege: advanced)-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of cancel operations.
[-unlock <Counter with Delta>]
- Unlock Operations (privilege: advanced)-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of unlock operations.
[-granted <Counter with Delta>]
- Granted Operations (privilege: advanced)-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of granted operations.
[-share <Counter with Delta>]
- Share Operations (privilege: advanced)-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of share operations.
[-unshare <Counter with Delta>]
- Unshare Operations (privilege: advanced)-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of unshare operations.
[-nmlock <Counter with Delta>]
- NmLock Operations (privilege: advanced)-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of nmlock operations.
[-freeall <Counter with Delta>]
- FreeAll Operations (privilege: advanced)-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of freeall operations.
[-total <Counter64 with Delta>]
- Total Operations (privilege: advanced)-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of total operations.
The following example displays statistics about the NLM for a node named node1:
cluster1::*> statistics nfs show-nlm -node node1 Node Value Delta node1 --------success------- Null: 0 - Test: 0 - Lock: 2 0/s:23s Cancel: 0 - Unlock: 1 0/s:23s Granted: 0 - Share: 0 - Unshare: 0 - NmLock: 0 - FreeAll: 0 - Total: 3 0/s:23s Node Value Delta node1 --------failure------- Null: 0 - Test: 0 - Lock: 0 - Cancel: 0 - Unlock: 0 - Granted: 0 - Share: 0 - Unshare: 0 - NmLock: 0 - FreeAll: 0 - Total: 0 -
